BretD
Mar 29, 2018Administrator
Update to the latest Nighthawk App (formerly NETGEAR Up) WiFi Simplified
“NETGEAR Up” is now the “Nighthawk App” with all the same great features and much more to come!
The Nighthawk® App makes it easy to set up your router and get more out of your WiFi. With...
rpmurph83
Apr 05, 2018Guide
just downloaded the app and i agree its about as useless as the genie app. I have an R7800 and the pause internet feature doesnt work on the genie app or on netgear up. You click the radio button to pause the internet for a device and 30 seconds later the button enables on its own. Same thing happens in the genie app. As a matter of fact the whole access control feature of the nighthawk routers doesnt work properly unless you want to use a workaround. Really wish netgear would address this...my last 4 highend routers have all been netgear, but my next will probably wont be if this continues.
