BretD
Mar 29, 2018Administrator
Update to the latest Nighthawk App (formerly NETGEAR Up) WiFi Simplified
“NETGEAR Up” is now the “Nighthawk App” with all the same great features and much more to come!
The Nighthawk® App makes it easy to set up your router and get more out of your WiFi. With...
PerfectRed
Apr 14, 2018Tutor
Does anyone know how to pause/resume and block devices on the iOS app? I have the header, but no buttons to switch on an off!
- Obiwan_Apr 14, 2018ApprenticeI have pause/ resume slide buttons for each device but if I try and disable anything, it says "TRY AGAIN LATER". There must be a MAGIC 8 BALL inside.
- PerfectRedApr 14, 2018TutorHow did you get the buttons to even appear? The header is there for me, but I have no buttons to slide.
Thanks for responding!- Obiwan_Apr 14, 2018Apprentice
The screen is just there. I have a R7900P.. I think you have an R8000. Netgear, as good as it was.... needs to get it together. The buttons are there... but they don't do anything. Might as well not even show up.
- Archie-17Apr 15, 2018Aspirant
我来自中国。
这个APP怎么下载呢?
- jdeleon6Jul 25, 2018Aspirant
I have this same problem. I have uninstalled and reinstalled the app several times and still no switches.
- schumakuJul 27, 2018Guru - Experienced User
Hard to say what "this same" problem is. Subject says "Update to the latest Nighthawk App (formerly NETGEAR Up) WiFi Simplified" do this does not look like a problem. What problem (as no NTGR moderator has managed to make your in-line photo accessible 24+ hours later) please - router not supported, any password oddities, ...?
- kboy24Jul 27, 2018ApprenticeFinally got that DD-WRT firmware off my box and got to download the lasted Netgear firmware loaded. Both Apps work great now. Major Pain though.
