BretD
Mar 29, 2018Administrator
Update to the latest Nighthawk App (formerly NETGEAR Up) WiFi Simplified
“NETGEAR Up” is now the “Nighthawk App” with all the same great features and much more to come!
The Nighthawk® App makes it easy to set up your router and get more out of your WiFi. With...
kboy24
Apr 16, 2018Apprentice
Then why is this called support!! Now I know why nothing it seems gets fixed here. Gracias for the Heads Up. Maybe a disclaimer would help. I didn't realize I was wasting my time here on this issue.
michaelkenward
Apr 16, 2018Guru - Experienced User
Try looking for the Solved tags on messages. You may be a disatisfied customer, but other people seem to appreciate the free help they get from unpaid volunteers.
- kboy24Apr 16, 2018Apprentice
Alright ya scolded me enough.Pull Up there Maverick. Do all these other disatisfied customers know about these volunteers? Why don't you give it a shot Superstar? It ain't solved yet or is anyone even bothering with it?
- michaelkenwardApr 16, 2018Guru - Experienced User
I'm afraid your problem got lost in the noise.
The Nighthawk app works fine here, but it seems to be a pointless tool that does nothing that I cannot achieve more easily with the browser interface, which is what most experienced troubleshooters recommend when setting up and managing a router.
The Android genie continues to be a better mobile controller.
Muchas Gracias SuperStar. More Noise. Isn't there someone you could be kinda helping instead of pissing on my leg
