Saltmarshgal
Dec 02, 2024Aspirant
Use a AX1800 wifi extender with orbi mesh. Router is Nighthawk 2050v
Hi, I'm trying to extend the range of our wireless network so an outdoor device will function better.
Current setup is Orbi mesh RBK752 with 2 satellites. Orbi Router is plugged into Nighthawk router CM 2050.
Pulled up the Nighthawk app and got the message that the AX1800 is not compatible with the range extender. Is there a way to make this work together or do I need to return the range extender?
Thanks in advance,
Jennie
I plugged in the extender, waited a bit and it appeared -- was able to join my house network no problem - so not sure what the incompatibility message was about!
- SaltmarshgalAspirant
NM... Figured it out.
What was the solution?
