Hartnett
Mar 14, 2024Guide
WGR614v10 setup?
I'm trying to use a WGR614v10 that has been reset (to its factory defaults). Everything I find about doing this points me to the NIGHTHAWK app. But the Nighthawk app DOESN'T support the WGR614v10. I'...
- Mar 14, 2024
For what it's worth...
I checked some notes I had from more than 10 years ago (so long ago I'd forgotten all about it), when I had an earlier version of the WGR614v10 (it was the -v9) that I setup for my parents, and I had the same problem(s) back then. The "fix" turned out to be accessing the router via "192.168.1.1/start.htm." I did that and the rest was, as they say, history (i.e., it worked fine)
Tom
Hartnett
Mar 14, 2024Guide
Hi,
This is a re-do if a post I did a few minutes ago...
I have a WGR614v10 that has been reset (to its factory defaults), and I'm trying to set it up.
I tried http://www.routerlogin.net and that took me to a Netgear page that told me to use the NIGHTHAWK app. But the NIGHTHAWK app DOESN'T support the WGR164v10.
Any pointers?
Thanks,
Tom
Mar 14, 2024Guru - Experienced User
usually at the bottom is a link "i don't have a smart phone". Click that.
I'd highly look at upgrading that router. its old, slow, and going to bottleneck pretty much anything you do
