Hartnett
Mar 14, 2024Guide
WGR614v10 setup?
I'm trying to use a WGR614v10 that has been reset (to its factory defaults). Everything I find about doing this points me to the NIGHTHAWK app. But the Nighthawk app DOESN'T support the WGR614v10. I'...
- Mar 14, 2024
For what it's worth...
I checked some notes I had from more than 10 years ago (so long ago I'd forgotten all about it), when I had an earlier version of the WGR614v10 (it was the -v9) that I setup for my parents, and I had the same problem(s) back then. The "fix" turned out to be accessing the router via "192.168.1.1/start.htm." I did that and the rest was, as they say, history (i.e., it worked fine)
Tom
Mar 14, 2024Guru - Experienced User
the defaults are usually
192.168.1.1
192.168.0.1
10.0.0.1
You can always use the command prompt to check its gateway if its not connected to a different router
Hartnett
Mar 14, 2024Guide
No luck...
Let me give you the "lay of the land" (if that helps):
I have an Xfinity Arris TG1682 Wireless gateway (I'll call this my "Main" SSID)
I have four wireless routers connected to the LAN ports of the Arris gateway
- A Netgear WNDR4500v3 N900 Wireless Router (SSID = N900)
- A Linksys MR7350 Wireless Router (SSID = MR3750)
- A Netgear EX6150v2 Range Extender (in "Access Point" mode) (SSID = EX6150), and
- the Netgear WGR614v10 (It's SSID is (presently) the factory default, NETGEAR)
If I connect (wirelessly) to the Arris gateway ("Main"), it says my default gateway is 10.0.0.1 and it says the IP address of the WGR614v10 is 10.0.0.237.
If I connect (wirelessly) to the Netgear WGR614v10, it says its default gateway is 192.168.1.1
- HartnettMar 14, 2024Guide
Tom
