rl032952
Feb 02, 2017Aspirant
where can i find a resource cd for n750(wndr4300)
need a resource cd for used n750 router wndr4300....any adeas? router is working but noe effeciently thanks
theno
Feb 03, 2017Aspirant
What you will do with CD? If it is not working effeciently than configure it. How CD can help you?
- rl032952Feb 03, 2017Aspirant
i dont have access to any "advanced" settings currently just basic
- michaelkenwardFeb 03, 2017Guru - Experienced User
You don't say which version of the router you have, but the manual here might help:
WNDR4300v2 | Product | Support | NETGEAR
If you don't want to use the browser interface – the best way to do these things – then the Netgear Genie might help.
- rl032952Feb 04, 2017Aspirant
guess i read wrong or something. i thought cd had advanced settings options to tweek signal strength
