rl032952
Feb 02, 2017Aspirant
where can i find a resource cd for n750(wndr4300)
need a resource cd for used n750 router wndr4300....any adeas? router is working but noe effeciently thanks
rl032952
Feb 03, 2017Aspirant
i dont have access to any "advanced" settings currently just basic
michaelkenward
Feb 03, 2017Guru - Experienced User
You don't say which version of the router you have, but the manual here might help:
WNDR4300v2 | Product | Support | NETGEAR
If you don't want to use the browser interface – the best way to do these things – then the Netgear Genie might help.
- rl032952Feb 04, 2017Aspirant
guess i read wrong or something. i thought cd had advanced settings options to tweek signal strength
- michaelkenwardFeb 04, 2017Guru - Experienced User
Anything that the CD provided is available through the browser interface or one of the various genies that Netgear provides. And they will be more up to date than anything on a CD. By the time a device reaches customers, the CD is usually out of date. That's one reason why they don't always provide one.
You still haven't told us which wndr4300 you have, here is a link to another one:
WNDR4300 | Product | Support | NETGEAR
The manual and relevant software are all there.
Page 34 of that one describes the advanced settings that you can get at.
By all means come back if you think something is missing or your get lost in the documentation .
