pine_tree
Dec 06, 2019Tutor
Where to download nighthawk-app for windows 10?
Does anyone know a safe website where I can download a no virus nighhawk-app for a PC running Widows 10? It is strange that netgear doesn't provide any weblink for its custmers to download such an a...
microchip8
Dec 06, 2019Master
you don't need apps. all you need is a browser and go to http://192.168.1.1 to use the router's Web GUI
pine_tree
Dec 06, 2019Tutor
Thank you so much!
I will try it right away. The tech support should have offered this solution in its website under the title how a PC to use netgear's wifi router.
By the way, where should I find the router's web GUI? What should I do about your following info?
Routing: NETGEAR R7800 - Voxel firmware 1.0.2.72SF
Switching: 2x NETGEAR 8-ports (GS108v4) / 1x NETGEAR 16-ports (JGS516v2)
Powerline: 2x NETGEAR PL1000
Storage: Custom-built Linux system
- pine_treeDec 06, 2019Tutor
It is indeed that Windows10 doesn't need any nighthawk-app-for-Windows10 in order for the netgear wifi router to work. Here is how to let Windows10 find the wifi signal.
1. Power up your netgear wifi router that is connected to the internet modem.
2. then you wil see the (((. symbol appear at the bottom-right conner of your PC's screen. Symbol (((. represents the existance of the wifi signal.
3. use your mouse to click on this symbol, then a list of the wifi signals will come up.
4. click the wifi signal that is generated by your router, then input the password of your router. Wala, right away your PC is connecting to the internet.
