pine_tree
Dec 06, 2019Tutor
Where to download nighthawk-app for windows 10?
Does anyone know a safe website where I can download a no virus nighhawk-app for a PC running Widows 10? It is strange that netgear doesn't provide any weblink for its custmers to download such an a...
ssnow73
May 31, 2020Initiate
microchip8 wrote:you don't need apps. all you need is a browser and go to http://192.168.1.1 to use the router's Web GUI
you are wrong about apps vs. the gui. apps are built for novices and for convenience. so easy to see what is connected to your router, changing passwords, speed test, rebooting, etc. netgear just needs to have the app built for a pc.
microchip8
May 31, 2020Master
All of that you can do with the Web GUI as well. NETGEAR's apps are very inconsistent and buggy. That's why I suggested to use the Web GUI
- labattJun 01, 2020Mentor
Besides what it stated above, don't do firmware updates via the app. Lots of bricked routers from people doing that. Bricked means router firmware is corrupt and then you have to go through a process that is not easy to recover.
