pine_tree
Dec 06, 2019Tutor
Where to download nighthawk-app for windows 10?
Does anyone know a safe website where I can download a no virus nighhawk-app for a PC running Widows 10? It is strange that netgear doesn't provide any weblink for its custmers to download such an a...
ssnow73
May 31, 2020Initiate
microchip8 wrote:you don't need apps. all you need is a browser and go to http://192.168.1.1 to use the router's Web GUI
you are wrong about apps vs. the gui. apps are built for novices and for convenience. so easy to see what is connected to your router, changing passwords, speed test, rebooting, etc. netgear just needs to have the app built for a pc.
BallzD33p
Sep 09, 2020Initiate
Yes...... we all now you can plug in your default gateway ip address into the URL bar to access the routers GUI.... but what if you were using 2 routers and or using the seond one as an access point... then your method falls short..... thats why we are looking specifically for an application
