pine_tree
Dec 06, 2019Tutor
Where to download nighthawk-app for windows 10?
Does anyone know a safe website where I can download a no virus nighhawk-app for a PC running Widows 10? It is strange that netgear doesn't provide any weblink for its custmers to download such an a...
kizzelwhix
Feb 08, 2021Initiate
I'm also looking for the genie/nighthawk software - while I can configure most things via the web GUI, the use of parental controls wants me to download the genie software (which I cannot find a legit source for). Unless there's some other way to configure the parental controls from the web gui (which I havn't seen yet). I'm running the latest firmware.
michaelkenward
Feb 08, 2021Guru - Experienced User
kizzelwhix wrote:
I'm also looking for the genie/nighthawk software...
If you are looking for an app for your mobile device, go to the appropriate Android/iPhone store. But neither supports parental controls.
Maybe you mean the desktop genie program. (There is no Nighthawk program.) If so, try this:
genie Landing Page | Apps | Discover | Home | NETGEAR
or
Another bolthole:
https://netgear.opendns.com/sign_in.php
