Dustin_V
Aug 05, 2019NETGEAR Employee Retired
WiFi Analytics is Now Available in the Latest Android Nighthawk App!
WiFi Analytics is now available in the latest Android Nighthawk App! With this feature, you can check your network status, WiFi signal strength, channel interference, and much more. Test it out and l...
schumaku
Aug 06, 2019Guru - Experienced User
Thank you Dustin_V we spotted this already. The user base would prefer getting the Netgear Live Parental Controls (LPC) back (including the individual device profile and the bypass account) as it was available on Genie before support was dropped for to many Nighthawk routers - which still support LPC.
- michaelkenwardAug 07, 2019Guru - Experienced User
Did I also see fingerprint login enabled in there too?
Or has that always been present?
- schumakuAug 07, 2019Guru - Experienced User
michaelkenward wrote:Did I also see fingerprint login enabled in there too? Or has that always been present?
It's around for some months/releases, one can enable Touch ID in the Account Management. The exact usage is unclear to me.
Funny part? Touch ID is an Apple registered trademark, not sure if Netgear can use this term e.g. here on the Android systems ChristineT
