Dustin_V
Aug 05, 2019NETGEAR Employee Retired
WiFi Analytics is Now Available in the Latest Android Nighthawk App!
WiFi Analytics is now available in the latest Android Nighthawk App! With this feature, you can check your network status, WiFi signal strength, channel interference, and much more. Test it out and l...
schumaku
Aug 15, 2019Guru - Experienced User
CLUBUGLY you can (among the complete Nighthawk App community threads) also start browsing my collection of issues with this App resp the interoperability with the managed router(s) -> https://community.netgear.com/t5/Nighthawk-App/BUG-REPORT-Speed-Test-Information-Home-Screen-Wrong-Speed-Test/m-p/1737540
PS. You still have not reported which router model, and t's firmware version you are referencing to. Issues and potential limitations (like your list of attached device icons) are related to the router firmware model and firmware version. And to make it worse - find the the proof provided in the link referred that the Nighthawk App devices icons don't match the selection e.g. on the ones available on the R9000/R8900 Web UI.
