Subadrew
Jun 19, 2017Aspirant
Wifi control via Genie app
Hello, I have a question regarding the Genie app. Is it possible to turn off your wifi signal from the app? I want to be able have my wifi signal off until my kids have gotten up and done their chore...
Subadrew
Jun 20, 2017Aspirant
I would like to use it on Android, or PC.
Thanks for your help!
michaelkenward
Jun 20, 2017Guru - Experienced User
Have you looked into the use of Parental Controls?
This is something that you can set up with the Android genie.
The R7000 supports this. See page 59 of the manual
R7000 | Product | Support | NETGEAR
It allows you to set time slots when the wifi network goes off line.
If you are using a PC, you can just go in there and turn access on and off.
