astroknit
Feb 24, 2023Tutor
wifi working but can't sign in as admin on Nighthawk app
I have a AC1750 Smart WiFi Router (R6700v3) with firmware V1.0.4.128_10.0.104. I signed into the Nighthawk app to check for firmware updates and it said there were none. I decided to reboot the r...
- Feb 25, 2023
Thank for the pointer. I had seen this thread earlier. I just didn't want go through the hassle of a factory reset. My brain is fuzzy since I'm not feeling well and I cannot access internet on my phone without wifi where I live. Anyway, long story short:
-factory reset
-reinstall app on iphone
-renamed network on website
-everything works now.
Bottom line: I won't use the app to reboot the router again. It has been working fine since 2019--until I did that reboot.
Feb 24, 2023Guru - Experienced User
You might give this a try:
If that fails, submit a bug report:
astroknit
Feb 25, 2023Tutor
-factory reset
