GPBritus
Oct 09, 2015Guide
Windows 10 will not open latest version 2.4.16.00 of genie.
V2.3.1.57 works fine under windows 10. Is netgear Investigating and issuing fixes?
- Nov 09, 2015
Hi GPBritus,
You can try installing version 2.4.12 as a temporary work around since it has worked for most, if not all, who are on Windows 10. You can use the download link below.
http://files.netgear-support.com/go/?a=d&i=k6XWUPGRaj
Dexter
Community Team
DexterJB
Nov 09, 2015NETGEAR Moderator
Hi GPBritus,
Dexter
Community Team
GPBritus
Nov 09, 2015Guide
2.4.12 works for now. Thank you Dexter.
