GPBritus
Oct 09, 2015Guide
Windows 10 will not open latest version 2.4.16.00 of genie.
V2.3.1.57 works fine under windows 10. Is netgear Investigating and issuing fixes?
- Nov 09, 2015
Hi GPBritus,
You can try installing version 2.4.12 as a temporary work around since it has worked for most, if not all, who are on Windows 10. You can use the download link below.
http://files.netgear-support.com/go/?a=d&i=k6XWUPGRaj
Dexter
Community Team
DcSpirou
Feb 06, 2016Aspirant
Hello to all and to all, please excuse my English because this is a translation. I have myself a problem with Netgear Genie whose several versions I tried (of 2.4.12 to the last version 2.4.20). My problem is not an error of launch of the program which dashes(launches) him(her) very well, only concerns(marigolds), it is that when is I restart the PC or if I him(her,it) put out(switched off) and relights him(it), Netgear Genie does not dash(launch) any more in the starting up. Thank you if somebody knows the problem, I am under Windows 10 Professional 64 Bits.
I forgot to tell you that I have R7000 and that with Windows 8.1 it worked very well, but since I installed Windows 10 there partition and formating my SSD, Netgear Genie launches well but does not launch automatically in the restart or by putting out(switching off) the PC and relighting him(it) later or later.
Cordially
