GPBritus
Oct 09, 2015Guide
Windows 10 will not open latest version 2.4.16.00 of genie.
V2.3.1.57 works fine under windows 10. Is netgear Investigating and issuing fixes?
- Nov 09, 2015
Hi GPBritus,
You can try installing version 2.4.12 as a temporary work around since it has worked for most, if not all, who are on Windows 10. You can use the download link below.
http://files.netgear-support.com/go/?a=d&i=k6XWUPGRaj
Dexter
Community Team
carll76
Oct 09, 2015Apprentice
they are aware...
and the thread I started as I missed thread one
I'm running 2.4.12 couldn't get .14 or .16 to run of surface pro 3.. .16 does run on my kids Lenovo laptop
- GPBritusOct 09, 2015Guide
Thanks for the information. I read another link that said that 2.4.16.00 IS the updated version. Unfortunately THEY are wrong. I look forward to a version that works.
- carll76Oct 09, 2015Apprentice
I'm new to netgear so don't really know what the update program is like interms of speed.
