GPBritus
Oct 09, 2015Guide
Windows 10 will not open latest version 2.4.16.00 of genie.
V2.3.1.57 works fine under windows 10. Is netgear Investigating and issuing fixes?
- Nov 09, 2015
Hi GPBritus,
You can try installing version 2.4.12 as a temporary work around since it has worked for most, if not all, who are on Windows 10. You can use the download link below.
http://files.netgear-support.com/go/?a=d&i=k6XWUPGRaj
Dexter
Community Team
carll76
Oct 09, 2015Apprentice
they are aware...
and the thread I started as I missed thread one
I'm running 2.4.12 couldn't get .14 or .16 to run of surface pro 3.. .16 does run on my kids Lenovo laptop
GPBritus
Oct 09, 2015Guide
Thanks for the information. I read another link that said that 2.4.16.00 IS the updated version. Unfortunately THEY are wrong. I look forward to a version that works.
- carll76Oct 09, 2015Apprentice
I'm new to netgear so don't really know what the update program is like interms of speed.
