mh-bfactor
Nov 03, 2016Aspirant
Wireless Router let WLAN devices into internet, but not in local network
Hello, I got a problem with our AC1200/R6220. The internal WLAN is configured only with 2.4 GHz online, no guest accounts. All WLAN accessed devices are connected to the internet, but devices in the...
- Nov 04, 2016
Hi mh-bfactor,
1. What is the firmware version of the router?
2. Have you tried resetting the router to factory defaults?
3. Have you tried re-flashing the latest firmware?
4. Do you have any static IP address configures to any of your device/s?
Dexter
Community Team
DexterJB
Nov 04, 2016NETGEAR Moderator
Hi mh-bfactor,
Dexter
Community Team
- mh-bfactorNov 04, 2016Aspirant
Hi,
the current firmware version is V1.1.0.34_1.0.1
Reset to factory defaults did match it, sorry for asking. The settings are the same as before, but now I can send a ping to our static IPs and to the router.
- DexterJBNov 07, 2016NETGEAR Moderator
