doredshiba's avatar
doredshiba
wirless phone application
Does this netgear 7800 be controlled by my cell phone?   Is there an application that I can download and use to control it?  Thank you in advance
  • michaelkenward's avatar
    michaelkenward
    Jun 27, 2020
    doredshiba wrote:
    Where and how in the browser do you control the modem?
    If you visit the support pages:
    Support | NETGEAR
    you can feed in your model number and find the documentation for your hardware.
    Check the section in the manual Log In to the Modem Router.
    Definitely a superior way of managing a modem/router.
