rfgrove
Apr 05, 2016Aspirant
WNDR3400 Can't forward both 80 and 443
I have a WNDR3400v2 router with firmware version V1.0.0.52_1.0.81
I'm trying to add port forwarding for ports 80 (to 8080) and 443 (to 8443).
I can add either one individually, but when I try to add both, a "port conflict" error message results when the second one is added.
Port conflict with other service.
I've tried adding them as custom services as well, with the same result.
- storm1985Prodigy
Remote management is using port 8443 by default. Change that port ( Advanced > Advanced Setup > Remote Management)
- rfgroveAspirant
Thanks, but that didn't help. My router is using port 8080 by default for remote management. I tried mapping 80=>8040 and 443=>8440, but I still get the same result. I can map either port individually, but when I try to map both, the port conflict error results.
- storm1985Prodigy
Try to disable HTTP and HTTPs over ReadyShare Storage tab
