golfer21
Oct 30, 2015Aspirant
WNDR3700v2 and Netgear Genie and Readyshare
I have a USB storage device connected to my router as \\readyshare and I can access it on the network. If I login to my router using a browser and 192.168.1.1, I can setup my router settings. I am ...
- Oct 30, 2015
Welcome to the community, golfer21
To answer your question, NETGEAR Genie is not supported on WNDR3700v2.
Here's the list of supported models and version of routers that will work with NETGEAR Genie.
The best way to access the hard drive is to use \\Readyshare or \\192.168.1.1 (IP Address of the router).
I hope this answers your question.
ElaineM
Oct 30, 2015NETGEAR Employee Retired
Netgear79
I have router R6700 and I get the same message on Netgear Genie
- DexterJBNov 02, 2015NETGEAR Moderator
Hi Netgear79,
The R6700 should support ReadyShare through the NETGEAR Genie.
1. What is the firmware version of the router?
2. What is the version of the NETGEAR Genie program?
3. Have you tried uninstalling and reinstalling the program?
Dexter
Community Team
- golfer21Nov 02, 2015Aspirant
Netgear WNDR3700v2 Router Firmware: V1.0.1.14
Netgear Genie Software Version: 2.4.16
Have I tried uninstalling and reinstalling? Yes
