golfer21
Oct 30, 2015Aspirant
WNDR3700v2 and Netgear Genie and Readyshare
I have a USB storage device connected to my router as \\readyshare and I can access it on the network. If I login to my router using a browser and 192.168.1.1, I can setup my router settings. I am ...
- Oct 30, 2015
Welcome to the community, golfer21
To answer your question, NETGEAR Genie is not supported on WNDR3700v2.
Here's the list of supported models and version of routers that will work with NETGEAR Genie.
The best way to access the hard drive is to use \\Readyshare or \\192.168.1.1 (IP Address of the router).
I hope this answers your question.
ElaineM
Oct 30, 2015NETGEAR Employee Retired
golfer21
Thank you for your response. Do you know if the WNDR3700v2 will be supported by Genie in a future WNDR3700v2 firmware upgrade or new Genie software version or will it never be supported by Genie?
