rileyrexj
Jul 14, 2017Aspirant
WNDR3800 Can't get into NETGEAR genie. Default admin username and/or password I put in are incorrect
WNDR3800 – N600 Wireless Dual Band Gigabit Router—Premium Edition
rileyrexj
Are there any consequences to resetting the router to factory defaults?
William10a
Jul 14, 2017Master
Reseting the router to default clears your settings and returns the router to out of the box state so you would have to reset up the router sometimes the only answer to fix a problem.
