amevans91's avatar
amevans91
Follower
Apr 06, 2017
WNR2000v5----unable to login through genie app after firmware update
unable to login to router through genie app after firmware update..............
  • Hi amevans91,
    Please make sure that you perform a factory reset after the firmware update. If the issue persists, try uninstalling and re-installing the Genie app and/or try using another device (Android, iOS, another computer).
    Dexter
    Community Team
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi amevans91,
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi amevans91,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
