bnich11
Apr 08, 2017Aspirant
WNR2000v5 Adding an Application for QoS "Port conflicts with another rule."
So I've been trying to understand and update the QoS on the WNR2000v5 router.
More speficially, I want to specify games that I will be running to operate at the highest priority. The available applications do not match what I am looking for, so I need to find a way to add a new one. For example, if I want to add League of Legends in the highest priority section, I fill in the required fields under the application "Other." I fill in the requirements (QoS Policy for: League of Legends | Priority: Highest | Connection Type : UDP | Starting Port: 5000 and Ending Port: 5500).
When I try to add this specifc application to the list, it errors me with the status "Port conflicts with another rule"
I removed all other rules from the highest category box and can't seem to get it to work. Any help would be greeatly appreciated.
Thanks
Perhaps there is a rule at a lower priority that conflicts with those ports.
- bnich11Aspirant
Is there an easy way to check each application for a port interference?
Not that I'm aware of.
