vivekl4k
Oct 07, 2016Follower
WNR614 STUCK ON WIFI ICON
WNR614 ROUTER IS STUCK ON THE WIFI ICON
TROUBLESHOOTING STEPS TRIED
FACTORYREST DOESNT WORK
POWERCYCLE NOT WORKING
UNABLE TO PERFORM FIRWARE UPDATE
KINDLY SUGGEST ANY OTHER TROUBLESHOOTING STEPS
- Retired_MemberOct 07, 2016
WHAT DO YOU MEAN STUCK ON WIFI ICON?
If you're saying the only LED working is WIFI then I would suspect hardware failure......replace it.
1 Reply
- Retired_Member
