Rizzo0849's avatar
Rizzo0849
Won't connect
Model number R6020 bought today plugged in like it says I can only get 3 of the 4 lights to come on
    What do you mean won't connect/
    The internet form the modem,by wifi, wired lan and what lights are you saying that come on?
  • I had all the cords hooked up how they are suppose to be there are 4 lights on the front first 3 light up and the fourth don't but if I unplug it and move one of the cords the fourth will light up but not third. My phone says connected to wifi but when I try to do anything then it says not connected. I switched back with my old router and everything works fine idk if I got just got a bad router now or what
    • William10a's avatar
      William10a
      Master
      Possible since you said you just get the router you try netgear tech support should be under warrenty or return it to the store
      • DexterJB's avatar
        DexterJB
        NETGEAR Moderator
        Hi Rizzo0849,
        I would like to follow up and check if you are still experiencing the issue.
        Dexter
        Community Team
