Frank1228
Apr 06, 2020Aspirant
wouldn't be able to login to nighthawk app model r7960p
hi there, i found i woudn't be able to to log on the nighthawk app, i tried delete the app and resinstall, and i have updated the firmware to V1.4.1.50_1.3.10 which i believe the newest version, but...
Frank1228
Apr 07, 2020Aspirant
its weird when i log on to the router setting page, it shows internet not connected,
while i can still use internet like watching youtube or browsing webpages.
anyone can help? thanks!
michaelkenward
Apr 07, 2020Guru - Experienced User
It might help if you told people what the modem is in front of this router. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
The reason for asking is that a lot of people turn up here trying to put a router behind a modem that is also a router.
- Frank1228Apr 07, 2020Aspirant
sorry, i'm using a CM1100 modem and nighthawk x6-ac3000 router. somehow the app works later last night, i don't know what happened, but i just login now. i do have another quesiton, my upload speed is extreamly low compare to the upload speed, like is 15 mbps vs 700 mbps, called comcast, its not their end issue. can you help?
- michaelkenwardApr 07, 2020Guru - Experienced User
I assume that you mean "my upload speed is extremely low compared to the download speed".
What upload speed are you paying for? Many services ha slower up than down. My down speeds is four or five times as fast as the up speed.
sorry, my typo, download speed is 650-700 mbps and upload is only 12-15 mbps, my package is 650 mbps download speed and upto 50 mbps upload speed, don't know why its so slow.
