BeefDaddy
Apr 03, 2019Follower
XR500 + Nighthawk iOS app = no devices listed
 I am unable to get the Nighthawk iOS app to show any of my connected devices, this appears to be a working feature based on other KB's I have run across.
 XR500 V2.3.2.40
DexterJB
May 20, 2019NETGEAR Moderator
Hi AdrianLab, welcome to the community! Upon checking on BeefDaddy's case, it looks like a factory reset on the XR500 resolved the issue. Is that something that you've tried before to fix the issue?
Dexter
- AdrianLabMay 20, 2019AspirantHi DexterJB, thanks for the reply. Following your suggestion I did a factory reset and then restored my settings (have a bunch of port redirections and IP's assigned I didn't want to lose or manually config again), after setting it all up and restoring the config, I went to my iOS app and opened the devices screen for my XR500 and got 0 devices again. - michaelkenwardMay 20, 2019Guru - Experienced User
 AdrianLab wrote:
 Following your suggestion I did a factory reset and then restored my settings ... If you restored settings from a backup, then you may also have restored the bug.
 Try it without restoring the settings.If it still does not work, then by all means restore the settings from your backup.
