BeefDaddy
Apr 03, 2019Follower
XR500 + Nighthawk iOS app = no devices listed
 I am unable to get the Nighthawk iOS app to show any of my connected devices, this appears to be a working feature based on other KB's I have run across.
 XR500 V2.3.2.40
AdrianLab
May 20, 2019Aspirant
Hi DexterJB, thanks for the reply.
Following your suggestion I did a factory reset and then restored my settings (have a bunch of port redirections and IP's assigned I didn't want to lose or manually config again), after setting it all up and restoring the config, I went to my iOS app and opened the devices screen for my XR500 and got 0 devices again.
michaelkenward
May 20, 2019Guru - Experienced User
AdrianLab wrote:
Following your suggestion I did a factory reset and then restored my settings ...
If you restored settings from a backup, then you may also have restored the bug.
Try it without restoring the settings.If it still does not work, then by all means restore the settings from your backup.
- DexterJBMay 29, 2019NETGEAR ModeratorHi AdrianLab, as suggested by michaelkenward, see if not restoring your config will give a different result. Keep us posted. Dexter - AdrianLabJul 23, 2019AspirantSorry for the suuuper late response, i decided to hold on to manually configure the router until appropiate, I did this yesterday, factory reset the XR500, set my dhcp and port forwarding manually without restoring any backup at all, and today I remembered about this and tried the app and sadly the app still shows no devices found in the device manager but also as an error now, I have the latest firmware.
