jlacasci
Oct 03, 2022Initiate
Auto crop for orientation canvas 2
I am interested in purchasing the 16x24 canvas II. I will not use the frame for art but for my own photographs. I intend to upload a playlist of both portrait and landscape images. If I mount the f...
Oct 03, 2022Guru - Experienced User
There's not a "yes/No" answer.
I have mine set to orientation match so it only displays photos that are in the proper orientation.
You can disable that so photos do fill but you'll have the black bars on it.
but there's also a "fill mode" where photos that don't match the orientation can be displayed. and how you want the edges displayed.
Not sure if that was helpful or not. I attached a photo of what fill mode is on mine.
- jlacasciOct 04, 2022Initiate
Thank you, that is helpful. I ordered the larger of the two canvas II products. It should be arriving tomorrow.
Joe
- plemansOct 05, 2022Guru - Experienced User
Hope it works well for you!
I mainly just use mine for photo displays as the wife likes the ease of adding photos to the playlist.
