Rich_R
Dec 22, 2022Aspirant
Black Screen randomly displays
Canvas software version 2.0.9 Good afternoon. I have seen this issue posted before from others, though I didn’t see a solution. When playing my Playlist, every fifth or so image is a black screen ...
- Dec 26, 2022Hi Rich - if it’s 4 years old then you’re well out of any Netgear or extended warranty, and consumer rights won’t be helpful here - 4 years is a good life and any longer is a plus. I’d enquire about repair costs but I’d be first tempted to try a factory reset and setup again from scratch. If the repair is too costly then I’d have a fiddle inside for any loose connectors as at that point you’ve got nothing to lose 🙂 Good luck!
Jeffgear
Dec 25, 2022Virtuoso
Looking at similar posts, this issue has been fixed by powering off the canvas for at least 30 seconds. Other posts suggested an RMA was the solution to their particular issue. Try the powering off and see if that resolves it.
Rich_R
Dec 26, 2022Aspirant
Thanks Jeff, for responding on Christmas!
I have tried powering off the Meural, but unfortunately it didn’t fix it. By “RMA” are you saying returning the unit? It’s been about 4 years so I assume I’m out of warranty. I could ask what the company would charge for a repair.
Thanks again,
Rich
Thanks again,
Rich
- JeffgearDec 26, 2022VirtuosoHi Rich - if it’s 4 years old then you’re well out of any Netgear or extended warranty, and consumer rights won’t be helpful here - 4 years is a good life and any longer is a plus. I’d enquire about repair costs but I’d be first tempted to try a factory reset and setup again from scratch. If the repair is too costly then I’d have a fiddle inside for any loose connectors as at that point you’ve got nothing to lose 🙂 Good luck!
- Rich_RJan 01, 2023Aspirant
Just adding one last comment here, in case anyone else has the same issue.
When I reached out to Netgear support, they suggested the following. It is not ideal (as the image orientation is now ignored), but it does work as the black screen images have stopped appearing so we are using this approach:
"Would request you to launch the Meural app, click on the Canvas option (bottom right), click on the settings icon (top right), click on Canvas Settings, scroll down and look for "orientation match". It should be turned off, for all the images (either vertical/horizontal) to get displayed on the Meural screen. If it is set to horizontal/vertical and based on how the Canvas is mounted on the wall, you will be able to see those images matching the Canvas' orientation and the rest of the images as a black screen."
