Devedander
Mar 19, 2022Aspirant
Canvas changes art even when Set to freeze
Despite setting my canvas to freeze it will randomly change pictures sometimes many times a day and sometimes not for days at a time.
I finally go so frustrated I setup a camera to record and make sure nothing was interfering.
I finally caught it switching. No one close or walked by or made a shadow.
It just changes.
I have a ticket open with netgear but haven’t heard anything back from them.
https://imgur.com/a/HLNPerY
It just changes.
- ChristineTNETGEAR Employee Retired
Hello Devedander ,
I am not able to replicate this issue however, we are still looking into this. Can you please share more about your Canvas settings? I assume you have Freeze Image enabled under Duration? A few other things to check:
- Can you please share the other settings under Duration?
- Playlist Rotation disabled?
- Image shuffle enabled?
Please also check to ensure your software is up to date? As I'm writing this I just checked my own software and there was a newer version available. Can you confirm which version you are seeing this issue on?
Many thanks,
Christine
- DevedanderAspirant
I included ask the settings in ticket but long an short of it is they sent me another unit and it did the same thing. It off box I only changed the image time to freeze and made sure auto updates were on. It only had the default sampler playlist.
For a week it would change one or more times a day. Once in the middle of the night when everyone was asleep and the curtains all drawn.
I captured several instances on my webcam and sent them in. I returned the new unit as it was no better than the old unit.
Still waiting on a response from support. The videos have a timestamp on them so I'm hoping there is some kind of log they can look at
- KevinLiTNETGEAR Moderator
Hello Davedander,
Thank you for bringing this issue to our attention!
Our support team will get in contact with you as soon as they are able to find a solution to this problem.
Please keep us updated on the progress of this issue as it may help out others in the community.
(Unfortunately, I had to remove the ticket number from the post)
Best,
Kevin
Community Team
