Jabecal
Jul 20, 2022Aspirant
Canvas II Restore Sample Playlist
Hi... How do I restore the sample playlist that came on my new Canvas II? Somehow I deleted it. Thank you
- Jul 21, 2022
Hello jabecal,
Welcome to the NETGEAR Community!
I understand that the sampler playlist that was delivered with your Meural Canvas II was accidentally removed. There is a section for a sample playlist on my.meural.com that will allow you to send the desired sample playlist to your Meural Canvas.
Please follow the instructions below to add the sample playlist to your Meural Canvas II.
- Navigate to my.meural.com
- Select browse
- Scroll down to the bottom of the page and select "Sampler"
- Next Select "Sampler Playlist"
- Next select "see all" on the right side of "Playlists"
- Then scroll down to the playlist that was accidentally deleted from your Meural Canvas
- Finally, select the three dots next to the desired sample playlist then select "Send to Meural"
Best,
Kevin
Community Team
KevinLiT
Jul 21, 2022NETGEAR Moderator
Hello jabecal,
- Select browse
Best,
Kevin
Community Team
- JabecalJul 29, 2022Aspirant
Thank you! This worked!
