isleslie
Apr 03, 2026Aspirant
Canvas Randomly Goes Offline
My Meural Canvas II keeps going off line. It seems to ne at random times. Sometimes it will stay connected for days. I’ve when I check the menu I just show “Loading…” where it should report my wifi. ...
isleslie
Apr 08, 2026Aspirant
No, it's still randomly going offline. I can see that the Canvas tries to periodically restart its wifi service while it is off line but it never reconnects without manual WPS intervention. I have a Home Assistant automation to notify me when it goes offline but I haven't been able to see any pattern to it.
- FURRYe38Apr 08, 2026Guru - Experienced User
Brand and model# of wifi router that the Canvas is connected too?
- isleslieApr 08, 2026Aspirant
Its a Bell Giga Hub 2.0.
Does the canvas connect at 2.4Ghz or 5Ghz?
Might ask the ISP or the Mfr if this Hub/router about changing wifi channels or if the SSID name can change to be separate.
Try channesl 1 and 40 or 11 and 48.
Check to see if there maybe neghboring WiFi neighbors that could be causing some interferences.
