Ak-Lex
Sep 29, 2024Apprentice
Canvas Says Offline
Hello My canvas is not coming online, I am connected to the network, however upon checking on the computer is says status offline. The app on the phone will not sync. I makes the connection to m...
- Oct 18, 2024
Hello Meural Community,
We are aware of the issue with the Meural server that is causing the Canvas I and Canvas II to appear offline on the Meural app and my.meural.com. Our Engineering team is diligently toward a solution to resolve this issue.We value your patronage and appreciate your patience!
Best,
Kevin
Community Team
Ak-Lex
Sep 30, 2024Apprentice
It’s on my home network, Asus Router I’ve always used on it, Meural says full wi-fi bars and connected to my network, however it’s showing offline.
I called customer service, explained to them and they said if I wanted to do a “special troubleshooting” I would have to buy extended warranty. It’s so unfair because my Meural doesn’t seem to be broken, and seems to be a software issue on network.
I did try using my iPhone as a hotspot and problem persisted, meaning it’s not a network problem on my end. Please help. I can’t have this bricked on me like this.
Sep 30, 2024Guru - Experienced User
1. what asus router?
2. what modem is the asus connected to?
3. is the asus using any type of access control/security that could potentially block?
4. did you try a factory reset on the canvas?
