Ak-Lex
Sep 29, 2024Apprentice
Canvas Says Offline
Hello My canvas is not coming online, I am connected to the network, however upon checking on the computer is says status offline. The app on the phone will not sync. I makes the connection to m...
- Oct 18, 2024
Hello Meural Community,
We are aware of the issue with the Meural server that is causing the Canvas I and Canvas II to appear offline on the Meural app and my.meural.com. Our Engineering team is diligently toward a solution to resolve this issue.We value your patronage and appreciate your patience!
Best,
Kevin
Community Team
Sep 30, 2024Guru - Experienced User
1. what asus router?
2. what modem is the asus connected to?
3. is the asus using any type of access control/security that could potentially block?
4. did you try a factory reset on the canvas?
Ak-Lex
Sep 30, 2024Apprentice
I don’t have the model in hands now, but I have always had it working on that router no problem. I also tried using on my iPhone hotspot, shows on canvas as connected but still offline when trying to connect via the app
- plemansSep 30, 2024Guru - Experienced User
Did you try factory resetting the Canvas?
Or deleting the network and reconnecting it?
- Ak-LexSep 30, 2024ApprenticeI did at least five factory reset in one day. Tried restarting network. Nothing brings it online.
- joey301Oct 01, 2024Star
Damn, I just bought the meural 2. I have had the Meural 1 for nearly 10 years and it has been flawless until it went offline about a week ago. I tried for hours to fix it to no avail, even being on chat with Meural support. I did all the stuff I have seen here, and nothing. I went to bed, the next morning, I turned on the Computer and the Meural was online. I think the problem is at Meural. I love this frame, I hope the new one works.
