Ak-Lex
Sep 29, 2024Apprentice
Canvas Says Offline
Hello My canvas is not coming online, I am connected to the network, however upon checking on the computer is says status offline. The app on the phone will not sync. I makes the connection to m...
- Oct 18, 2024
Hello Meural Community,
We are aware of the issue with the Meural server that is causing the Canvas I and Canvas II to appear offline on the Meural app and my.meural.com. Our Engineering team is diligently toward a solution to resolve this issue.We value your patronage and appreciate your patience!
Best,
Kevin
Community Team
tekntonk
Sep 28, 2024Guide
This is regarding my MC227 canvas. The canvas has disconnected from the WiFi in my home, and stubbornly refuses to behave as if it is connected so it can receive new artwork images, despite displaying the correct name of my WiFi network both on the canvas itself and in the app / website portal and appearing in that way to in fact be connected properly — the canvas looks like it is connected to my WiFi, but the app and the website portal say the canvas is Offline; my router even shows real-time traffic for the canvas.
I have the following steps: 1) I have restarted the WiF from the canvas menui. 2) I have ‘Cleared All WiFi Connections’ and attempted to reconnect that way. 3) I have removed and re-added the canvas to my account, triggering the QR-Code setup process. 4) I have attempted to factory-reset the canvas using the instructions under the support area for this product, but although I can hear a faint click when the paper clip I am using to press the teeny tiny curse-ed button inside the canvas frame as directed, when following the correct reset steps, the canvas does not reset but behaves as if no reset commands were given.
Is there any way to resolve this?
KevinLiT
Sep 30, 2024NETGEAR Moderator
Hello tekntonk,
Welcome to the NETGEAR Community!
I understand that you are having trouble factory resetting your Meural Canvas.
Please try the following steps to successfully factory reset your Meural Canvas:
- Unplug your Meural Canvas
- Hold down the reset button
- Plug in your Meural Canvas while holding down the reset button.
- Wait 20 seconds
- Now release the reset button
Best,
Kevin
Community Team
