Ak-Lex
Sep 29, 2024Apprentice
Canvas Says Offline
Hello My canvas is not coming online, I am connected to the network, however upon checking on the computer is says status offline. The app on the phone will not sync. I makes the connection to m...
- Oct 18, 2024
Hello Meural Community,
We are aware of the issue with the Meural server that is causing the Canvas I and Canvas II to appear offline on the Meural app and my.meural.com. Our Engineering team is diligently toward a solution to resolve this issue.We value your patronage and appreciate your patience!
Best,
Kevin
Community Team
KarenStA
Oct 03, 2024Guide
Having the same problem with three devices. Worked on Friday, didn't connect on Monday. WTF
- Ak-LexOct 03, 2024ApprenticeSo I came home excited because the chat moderator told me it was fixed. It’s not fixed. I even tried on an android phone and the app will not connect, says offline even tho it has full WiFi signal connected to my network
- KarenStAOct 03, 2024Guide
I use mine for events. Had our IT department send a tech to the office to check out the wifi to make sure all was in order. Yup. Tried connecting to our three different wifi networks, plus hotspotting off his phone. All wifi networks are strong (and other devices connect without issue).
The devices worked fine on September 20. Not on September 21. What did Netgear do that day to change things?
- bparasOct 03, 2024Guide
I have the Meural Canvas II MC227... +1 with the same issue as everyone. Hopefully Netgear finds a resolution.
