Ak-Lex
Sep 29, 2024Apprentice
Canvas Says Offline
Hello My canvas is not coming online, I am connected to the network, however upon checking on the computer is says status offline. The app on the phone will not sync. I makes the connection to m...
- Oct 18, 2024
Hello Meural Community,
We are aware of the issue with the Meural server that is causing the Canvas I and Canvas II to appear offline on the Meural app and my.meural.com. Our Engineering team is diligently toward a solution to resolve this issue.We value your patronage and appreciate your patience!
Best,
Kevin
Community Team
bparas
Oct 04, 2024Guide
Mine as of this morning is back in Idle/online mode. Just noticed that a playlist I sent to it yesterday finally made it to my Canvas. I did try the Wifi reset/clear but that didn't do anything initially and didn't bother resetting it once I came across this thread.
Hopefully others here eventually see theirs online 🤞
- Ak-LexOct 04, 2024ApprenticeI can’t even send playlist because the app wind synch
- DrSharonOct 05, 2024Guide
Weirdly, my newer Canvas, bought 2022, is still connecting to the app, but my older 2nd generation one, bought 2017, stopped connecting like other people in this thread a week or so ago. Both are connected to the same wifi with strong signal.
Sharon
- Ak-LexOct 05, 2024ApprenticeHi Sharon,
That’s actually good feedback, at least they can narrow down to possibly a firmware update on the older Meurals.
I haven’t heard of a solution yet.
- bparasOct 05, 2024GuideAnd after getting online yesterday, my canvas is back to being offline. So frustrating!
- DrSharonOct 06, 2024Guide
My canvas re-connected to the Meural app on my iPhone last night, and this morning it has reconnected through the Netgear/Meural website on my laptop.
There is hope!
I hope it lasts...
Sharon
- Ak-LexOct 06, 2024ApprenticeHi Sharon, thanks for sharing, I’ll try mine.
- Ak-LexOct 06, 2024ApprenticeThat’s frustrating. Sharon was able to get hers online. I had hopes and came to try mine, did a reset and no luck. At this time I unplugged from the wall and only plug it in when trying for a connection.
I’m still offline- joey301Oct 06, 2024Star
Sometimes, my frame will say offline, but later when I come back, what i had tried to upload is there. So, it seems they come online for a little while and then go offline.
