Ak-Lex
Sep 29, 2024Apprentice
Canvas Says Offline
Hello My canvas is not coming online, I am connected to the network, however upon checking on the computer is says status offline. The app on the phone will not sync. I makes the connection to m...
- Oct 18, 2024
Hello Meural Community,
We are aware of the issue with the Meural server that is causing the Canvas I and Canvas II to appear offline on the Meural app and my.meural.com. Our Engineering team is diligently toward a solution to resolve this issue.We value your patronage and appreciate your patience!
Best,
Kevin
Community Team
bparas
Oct 04, 2024Guide
Mine as of this morning is back in Idle/online mode. Just noticed that a playlist I sent to it yesterday finally made it to my Canvas. I did try the Wifi reset/clear but that didn't do anything initially and didn't bother resetting it once I came across this thread.
Hopefully others here eventually see theirs online 🤞
bparas
Oct 05, 2024Guide
And after getting online yesterday, my canvas is back to being offline. So frustrating!
- DrSharonOct 06, 2024Guide
My canvas re-connected to the Meural app on my iPhone last night, and this morning it has reconnected through the Netgear/Meural website on my laptop.
There is hope!
I hope it lasts...
Sharon
- Ak-LexOct 06, 2024ApprenticeThat’s frustrating. Sharon was able to get hers online. I had hopes and came to try mine, did a reset and no luck. At this time I unplugged from the wall and only plug it in when trying for a connection.
I’m still offline- joey301Oct 06, 2024Star
Sometimes, my frame will say offline, but later when I come back, what i had tried to upload is there. So, it seems they come online for a little while and then go offline.
- EladspiraOct 06, 2024InitiateI’m told to run factory reset. I’m afraid it will wipe out everything that’s now working.
What do I do?
