Ak-Lex
Sep 29, 2024Apprentice
Canvas Says Offline
Hello My canvas is not coming online, I am connected to the network, however upon checking on the computer is says status offline. The app on the phone will not sync. I makes the connection to m...
- Oct 18, 2024
Hello Meural Community,
We are aware of the issue with the Meural server that is causing the Canvas I and Canvas II to appear offline on the Meural app and my.meural.com. Our Engineering team is diligently toward a solution to resolve this issue.We value your patronage and appreciate your patience!
Best,
Kevin
Community Team
Kenez
Oct 05, 2024Initiate
Hello, My Meural has been working fine until yesterday when it lost connectivity. It still says it is connected to my home network but to be sure I repeated the WiFi setup steps. Both the app and website say "frame offline". The frame itself says it is connected to my network but server status is "offline". Could this mean that the problem is on Netgear's end? Otherwise, anything I can try to restore connectivity? See frame status below. Thanks.
georgepaul123
Having the same issue with server connectivity. Can't find a resolution to it yet.
