JoFeRoGo
Dec 25, 2021Aspirant
Connexion impossible
Bonjour, J'ai acheté un Meural MC315 et impossible de me connecter avec l'application Android ! J'ai toujours le même message "Le canevas est déjà enregistré" !!! C'était un article en expositi...
JoFeRoGo
Hello,
Thank you for your reply.
...in English
I bought a Meural MC315 and I can't connect with the Android app!
I always get the same message "The canvas is already saved"
"...it seems that your work area has been set up with another account or the device key is incorrect. Try again or contact technical support."
This was an item on display in the shop and I'm wondering if an account was made by them and now impossible to log in with a new account!
Can you please help me?
Thank you very much.
DexterJB
Dec 28, 2021NETGEAR Moderator
Hi JoFeRoGo, we recommend contacting our support team to get this sorted out. You can check the link below for more info on how to reach them.
https://kb.netgear.com/000060722/How-do-I-get-in-touch-with-Meural-customer-support
Dexter
Meural Team
