jacksonvld's avatar
jacksonvld
Follower
Mar 14, 2020
Create script sharing - ReadyNAS516
Gentlemen, I want to automate the creation of sharing with ansible on my 30 network readynas. The idea is to create the share with all the permissions defined. I searched the forum and the internet and found nothing similar, so I appeal to the community.
Has anyone managed to create any shares using script?
1 Reply
  • NG_Team's avatar
    NG_Team
    NETGEAR Moderator
    You have posted your ReadyNAS question in the Meural forums, so unfortunately this is not where you will get responses.  If you post in the ReadyNAS forums the ReadyNAS Community should be able to help you.
    NETGEAR Team
