VancouverCanada
Dec 27, 2019Aspirant
Does the Meural Canvas II have a dual voltage adapter?
Hi there, I’m wondering if the adapter supplied with the Meural Canvas II supports dual voltage—basically if I purchase and then move to a country that has higher voltage, will this still work? (I re...
VancouverCanada
Jul 31, 2020Aspirant
Thanks for noting the option. It would be much easier if there was one supplied plug that could handle both voltages, like most modern electronics. Especially since the product is sold in places with different voltages. Maybe next model.
Fanisp
Sep 29, 2020Aspirant
Did you find a solution? I am on the same boat. I brought it to Europe and not sure what to do - I am afraid to plug it and cant find an adapter that fits the back the same - any help will be appreciated.
- VancouverCanadaSep 30, 2020AspirantIt’s not clear if newer models will include an adapter for both voltages (but should). The only other option is to search online for the correct adapter. A specific adapter wasn’t listed, but it might be worth a shot at looking on AliExpress or Amazon. I haven’t purchased a Canvas yet, a result of the overlooked adapter issue. Let us know the specific model if you do find one that’s sufficient! Thanks.
- richgriffNov 03, 2020AspirantI have just purchased a MC327LW Canvas II and can confirm it works fine in the UK which has a 240V power supply. I'd now like to connect to a socket already in the wall behind another photo frame I already had so need to know if the voltage adapter is in the plug or in the unit, does anyone know?
- VancouverCanadaNov 03, 2020AspirantThe voltage adapter would be in the plug, usually the box-like part of the power plug.
