Christiborden
Jun 21, 2022Follower
Help. My Meural power cord broke.
How can I get a replacement?
Jun 21, 2022Guru - Experienced User
Netgear doesn't sell replacement power supplies. Your best bet is to see if someone on fleabay is selling one or just buy a matching 3rd party supply. You just need to make sure the output voltage and polarity are the exact same. You can have a higher amperage but don't have less.
Jeffgear
Jun 28, 2022Virtuoso
Wouldn't it be awesome if Netgear sold replacement power adaptors for all their range in whatever country format was required or created a universal one with an interchangeable power plug adapter? I'd probably purchase a spare or two to have in reserve.
