prietojr
Feb 07, 2024Aspirant
Horizontal lines on Canvas 1
I have horizontal lines on my Canvas version 1. It is only at the very top of the screen. I looked inside to make sure the ribbon cable that goes to the LCD screen was in and did not loosen up. Every...
prietojr
May 03, 2024Aspirant
Following this. I have the exact same problem. Netgear support is useless. Would like to fix also since other than that it is fine.
